control-bar_audio-track-controls_audio-track-menu-item.js
 * @file audio-track-menu-item.js
import MenuItem from '../../menu/menu-item.js';
import Component from '../../component.js';
import * as Dom from '../../utils/dom.js';
 * An {@link AudioTrack} {@link MenuItem}
 * @extends MenuItem
class AudioTrackMenuItem extends MenuItem {
   * Creates an instance of this class.
   * @param { import('../../player').default } player
   *        The `Player` that this class should be attached to.
   * @param {Object} [options]
   *        The key/value store of player options.
  constructor(player, options) {
    const track = options.track;
    const tracks = player.audioTracks();
    // Modify options for parent MenuItem class's init.
    options.label = track.label || track.language || 'Unknown';
    options.selected = track.enabled;
    super(player, options);
    this.track = track;
    this.addClass(`vjs-${track.kind}-menu-item`);
    const changeHandler = (...args) => {
      this.handleTracksChange.apply(this, args);
    tracks.addEventListener('change', changeHandler);
    this.on('dispose', () => {
      tracks.removeEventListener('change', changeHandler);
  createEl(type, props, attrs) {
    const el = super.createEl(type, props, attrs);
    const parentSpan = el.querySelector('.vjs-menu-item-text');
    if (['main-desc', 'description'].indexOf(this.options_.track.kind) >= 0) {
      parentSpan.appendChild(Dom.createEl('span', {
        className: 'vjs-icon-placeholder'
        'aria-hidden': true
        className: 'vjs-control-text',
        textContent: ' ' + this.localize('Descriptions')
    return el;
   * This gets called when an `AudioTrackMenuItem is "clicked". See {@link ClickableComponent}
   * for more detailed information on what a click can be.
   * @param {Event} [event]
   *        The `keydown`, `tap`, or `click` event that caused this function to be
   *        called.
   * @listens tap
   * @listens click
  handleClick(event) {
    super.handleClick(event);
    // the audio track list will automatically toggle other tracks
    // off for us.
    this.track.enabled = true;
    // when native audio tracks are used, we want to make sure that other tracks are turned off
    if (this.player_.tech_.featuresNativeAudioTracks) {
      const tracks = this.player_.audioTracks();
      for (let i = 0; i < tracks.length; i++) {
        const track = tracks[i];
        // skip the current track since we enabled it above
        if (track === this.track) {
          continue;
        track.enabled = track === this.track;
   * Handle any {@link AudioTrack} change.
   *        The {@link AudioTrackList#change} event that caused this to run.
   * @listens AudioTrackList#change
  handleTracksChange(event) {
    this.selected(this.track.enabled);
Component.registerComponent('AudioTrackMenuItem', AudioTrackMenuItem);
export default AudioTrackMenuItem;
